Home > Maintenance & Modifications > Changing the diff lock switch on lt230
Bluest
Is this just a case of screw old on out, screw new one in? Does oil pour out or any other pitfalls? 2007 110 TDCi Station Wagon XS
Post #1039362 7th Jul 2024 2:01pm
rustandoil
Yup, old one out.... New one in nowhere near any oil
Post #1039365 7th Jul 2024 2:29pm
Bluest
Thanks, I spent a frustrating 30 mins trying and failing to disconnect the electrical plug. I reach it OK over the chassis rail, but no amount of wiggling and poking with a screwdriver would get it to budge. 2007 110 TDCi Station Wagon XS
Post #1039404 7th Jul 2024 8:58pm
rustandoil
You might be better off by removing the cubby box and the panel underneath it and tackle the job from above
Post #1039412 8th Jul 2024 7:03am
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
Definitely a job easier from above 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1039413 8th Jul 2024 7:13am
Bluest
Thanks I might have to bite the bullet. I was trying to avoid removing the cubby as I have a Mud locker underneath it with an auxiliary fuse box in there and a rats nest of wiring. 2007 110 TDCi Station Wagon XS
Post #1039480 8th Jul 2024 8:17pm
Bluest
Did it yesterday through the panel under the cubbybox as suggested. Forearms shredded, precious 19mm spanner hacksawed in half to make a stubby. Once the high/low selector is popped off it not actually that bad of a job. 2007 110 TDCi Station Wagon XS
Post #1040045 15th Jul 2024 9:25pm
