Home > Puma (Tdci) > Puma 2.2 metal in sump
Ambo_Chris
United Kingdom 2013 Defender 110 Puma 2.2 USW Baltic Blue
Below are some pics of a piece of metal that came out on the sump plug when changing the oil. Does anyone have any ideas what it could be? There was no swarf and the oil was last changed about 2000 miles ago with nothing unusual. Truck rubs absolutely fine.
 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
2000 Beige Discovery 2 Td5 GS (Long gone)
1994 Red (various) 90 300tdi CSW (Long gone)
Post #1038843 1st Jul 2024 9:16am
Siwynne
Looks like a head to block locating dowel. They can’t get out whilst engine is assembled though
Post #1038904 1st Jul 2024 7:29pm
Siwynne
Post #1038905 1st Jul 2024 7:30pm
MK
For a peace of mind I would compare with TYT500020 or LR004348 Puma 110" SW
Post #1038918 1st Jul 2024 10:56pm
Ambo_Chris
Fantastic, good news I guess? 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
Post #1038929 2nd Jul 2024 7:48am
Ianh
Unless someone has had the engine apart then I suspect the dowel has been in their from assembly. Hopefully it’s not missing from the engine, just a “spare “ that the ford kindly left in your sump in case you ever needed it. Rolling Eyes The sump has its own magnet so given you have an aftermarket magnetic drain plug I guess it dislodged from the sump magnet and attached to the plug magnet.
Post #1038950 2nd Jul 2024 11:04am
MK
I was not aware the oil sump had a magnet. Puma 110" SW
Post #1038972 2nd Jul 2024 4:29pm
Ianh
Sorry , having a brain fade today, it’s the gearbox that has a magnet fitted, not the engine sump.
Post #1038982 2nd Jul 2024 6:11pm
Ambo_Chris
It is a replacement engine done by the previous owner. Not sure of the source but it is a later engine with the screw on type oil filter rather than the insert type. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
Post #1039099 4th Jul 2024 6:48am
hank
Did you fit the magnet at that last oil change 2000 miles ago? Strange for that dowel to appear now and not then > 110 XS Double Cab
Post #1039105 4th Jul 2024 7:58am
Ambo_Chris
No I’m pretty sure it was already on there and obviously there was nothing on there then. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
Post #1039231 5th Jul 2024 5:14pm
