Home > Puma (Tdci) > Puma 2.2 metal in sump |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 588 |
Looks like a head to block locating dowel. They can’t get out whilst engine is assembled though
1st Jul 2024 7:29pm |
Click image to enlarge |
1st Jul 2024 7:30pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2431 |
For a peace of mind I would compare with TYT500020 or LR004348 Puma 110" SW
1st Jul 2024 10:56pm |
Ambo_Chris Member Since: 01 Dec 2021 Location: South West Posts: 31 |
Fantastic, good news I guess? 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
2nd Jul 2024 7:48am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2052 |
Unless someone has had the engine apart then I suspect the dowel has been in their from assembly. Hopefully it’s not missing from the engine, just a “spare “ that the ford kindly left in your sump in case you ever needed it. The sump has its own magnet so given you have an aftermarket magnetic drain plug I guess it dislodged from the sump magnet and attached to the plug magnet.
2nd Jul 2024 11:04am |
I was not aware the oil sump had a magnet. Puma 110" SW
2nd Jul 2024 4:29pm |
Sorry , having a brain fade today, it’s the gearbox that has a magnet fitted, not the engine sump.
2nd Jul 2024 6:11pm |
It is a replacement engine done by the previous owner. Not sure of the source but it is a later engine with the screw on type oil filter rather than the insert type. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
4th Jul 2024 6:48am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2303 |
Did you fit the magnet at that last oil change 2000 miles ago? Strange for that dowel to appear now and not then > 110 XS Double Cab
4th Jul 2024 7:58am |
No I’m pretty sure it was already on there and obviously there was nothing on there then. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
5th Jul 2024 5:14pm |
