Home > In Car Electronics (L663) > Meridian to retrofit Meridian Surround Amplifier |
awktm Member Since: 19 Jun 2024 Location: Melbourne Posts: 14 |
This might help someone, I have worked out these are the pinouts:
Click image to enlarge I have now wired in the amp to all existing 11 speakers and working. I now need to add the rears in the headlining (or similar location) as the backup sensors beep on those speakers. I would also like to add the front mid and tweeter to get a better soundstage. Next project is working out how I wire up through the telematics module so I don't lose the telematics function. Click image to enlarge Click image to enlarge |
7th Aug 2024 11:12am |
elvin Member Since: 24 Apr 2023 Location: Victoria Posts: 4 |
Impressive! Thank you for posting this and keen to see any more follow ups!
8th Aug 2024 3:16am |
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 253 |
Indirectly related:
Can you confirm that the front centre speaker above the front air vents is present (it is there for me) but it is not active and there is no sound? And if I were to retrofit the Meridian Surround Amp then this would 'activate' the front centre speaker? 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
8th Aug 2024 6:45am |
It is a different speaker, you would need to upgrade that speaker and also add the tweeter. You would then need to activate the speaker and run wires for the tweeter.
I am happy with the sound without the front centre channel |
14th Sep 2024 1:23pm |
