![]() | Home > Puma (Tdci) > No Start/crank. Temp needle on max. No glow plug light |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
Check the relays as well. The ECU is fed by a fuse and a relay. I don't have the wiring diagram handy to tell you which ones but I'm sure the info is out there.
Esben Kold Member Since: 14 Oct 2023 Location: Horsens Posts: 28 ![]() ![]() ![]() |
I had a similar issue when the connector on the back of the instrument had some how worked itself loose.
