Home > Puma (Tdci) > No Start/crank. Temp needle on max. No glow plug light |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 566 |
Check the relays as well. The ECU is fed by a fuse and a relay. I don't have the wiring diagram handy to tell you which ones but I'm sure the info is out there.
27th Jun 2024 5:49pm |
Esben Kold Member Since: 14 Oct 2023 Location: Horsens Posts: 14 |
I had a similar issue when the connector on the back of the instrument had some how worked itself loose.
29th Jun 2024 7:52am |
