Home > Puma (Tdci) > Chasing Engine issues on my 2.4 Puma
Page 2 of 2 <12
jf_est
Estonia 2007 Defender 90 Puma 2.4 SW Java Black
I didn't update this thread, but it turns out there was an issue with my engine where the camshaft was coming into contact with a valve and causing wear. This is the root of the noise that I was hearing.
Luckily a local engine shop was experienced with this issue with another Defender (not sure how common this is), and they were able to sort the issue with the rocker assembly and replace the camshaft. It runs a lot better now, but I wouldn't say it was perfect.
They shared an overview of the issue on their instagram: https://www.instagram.com/reel/C94r5HGt9kW...BiNWFlZA==
Post #1060830 18th Feb 2025 8:28am
^^ Looks like one cam has slipped on the camshaft (the most damaged cam and the adjacent one are clearly not aligned).
What fool thought that press-fitting the cams on the camshaft was a good idea? What was wrong with solid ground camshafts?
Post #1060835 18th Feb 2025 10:45am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Ok, 35 years as a mechanic and 5 years in a busy retirement (2 Lotuses, 2 Land Rovers and innumerable bicycles, scooters and motorbikes) and THAT is a new one on me, cool.
Post #1060854 18th Feb 2025 2:55pm
Page 2 of 2 <12
