- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
jf_est
I didn't update this thread, but it turns out there was an issue with my engine where the camshaft was coming into contact with a valve and causing wear. This is the root of the noise that I was hearing.
Luckily a local engine shop was experienced with this issue with another Defender (not sure how common this is), and they were able to sort the issue with the rocker assembly and replace the camshaft. It runs a lot better now, but I wouldn't say it was perfect.
They shared an overview of the issue on their instagram: https://www.instagram.com/reel/C94r5HGt9kW...BiNWFlZA==
18th Feb 2025 8:28am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
