![]() | Home > General & Technical (L663) > Rear position lights |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2703 ![]() ![]() |
Turn the side lights on and then you’ll have position lights front and rear.
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 98 ![]() ![]() |
I know that 😁
I would have just liked the rear lights to be all the time like on my D5 |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1217 ![]() ![]() |
I have done this mod, that you require.
So the lights on the front are White until you put the Amber indicator on. The rear, smaller lamps are Red whilst the "ignition" is on, WITHOUT the larger lamps being on and the inner portion flash Amber with indicators. Yes, you can turn on the sidelamps, BUT you get both smaller lamps AND the larger lamps on. What you require is to cut into the rear lamp cluster, where you will find a 5-wire cable form that links the two circuit boards which control the smaller and larger lamps. I can NOT advise anyone to do the same, as if you don't know what you are doing you could destroy both sets of lamp clusters. Sorry. ![]() Click image to enlarge |
Thanks, but that would only turn in the rear lights on the car… it wouldn’t turn on the lights on a trailer.
On the D5, there were settings in the CCF that can determine this type of thing. Does this not exist on the Defender? |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1444 ![]() ![]() |
Why not just turn the lights on to turn the trailer lights on? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Brulz Member Since: 07 May 2021 Location: Brescia Posts: 35 ![]() ![]() |
I'd like to do the same.... I'vd done a lot of CCF setting without success.. On D5 witch Multixxxxx? (maybe I can investigate on it...) |
Somewhere in my past, I seem to remember, that the Freelander 2 had such a link in the ccf for the Japan market. ???
I know that I could just turn them on and off manually... it is more a case that I have Auto Headlights and am used to simply relying on that... |
On the Discovery 2 it was the SWEDEN setting that had this. |
I don't know which setting it is... sorry. I was told by LR that it is a regional setting, and since the wiring will be the same for all regions, I was HOPING that it can be changed on my Def. |
