Home > General & Technical (L663) > Rear position lights
nebc100
Luxembourg
Hello All,
Does anyone know how I can get the rear position lights to be on with the DRLs.
I have this on my D5, and it is really useful as it turns on the position lights on my horse trailer while I am towing without having to turn the main lights on etc.
Thanks for you help!!
Nick
Post #1036911 9th Jun 2024 12:33pm
Retroanaconda
Turn the side lights on and then you’ll have position lights front and rear.
Post #1036917 9th Jun 2024 1:06pm
nebc100
Luxembourg
I know that 😁
I would have just liked the rear lights to be all the time like on my D5
Post #1036918 9th Jun 2024 1:08pm
LR Nuts
I have done this mod, that you require.
So the lights on the front are White until you put the Amber indicator on.
The rear, smaller lamps are Red whilst the "ignition" is on, WITHOUT the larger lamps being on and the inner portion flash Amber with indicators.
Yes, you can turn on the sidelamps, BUT you get both smaller lamps AND the larger lamps on.
What you require is to cut into the rear lamp cluster, where you will find a 5-wire cable form that links the two circuit boards which control the smaller and larger lamps.
I can NOT advise anyone to do the same, as if you don't know what you are doing you could destroy both sets of lamp clusters.
Sorry.
Post #1036926 9th Jun 2024 2:20pm
nebc100
Luxembourg
Thanks, but that would only turn in the rear lights on the car… it wouldn’t turn on the lights on a trailer.
On the D5, there were settings in the CCF that can determine this type of thing. Does this not exist on the Defender?
Post #1036940 9th Jun 2024 3:42pm
Moo
Ukraine
Why not just turn the lights on to turn the trailer lights on? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1036948 9th Jun 2024 4:36pm
Brulz
Italy
I'd like to do the same....
I'vd done a lot of CCF setting without success..
On D5 witch Multixxxxx? (maybe I can investigate on it...)
Post #1036955 9th Jun 2024 5:16pm
LR Nuts
Somewhere in my past, I seem to remember, that the Freelander 2 had such a link in the ccf for the Japan market. ???
Post #1036964 9th Jun 2024 5:36pm
nebc100
Luxembourg
I know that I could just turn them on and off manually... it is more a case that I have Auto Headlights and am used to simply relying on that...
Post #1036968 9th Jun 2024 6:34pm
nebc100
Luxembourg
On the Discovery 2 it was the SWEDEN setting that had this.
Post #1036969 9th Jun 2024 6:35pm
nebc100
Luxembourg
I don't know which setting it is... sorry.
I was told by LR that it is a regional setting, and since the wiring will be the same for all regions, I was HOPING that it can be changed on my Def.
Post #1036971 9th Jun 2024 6:37pm
