![]() | Home > Maintenance & Modifications > Whats better |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Vision Plus (or Halfords) uprated rear bulbs
or LED bulbs? Mike |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
what sort of uprated rear bulbs?
like this:
http://www.powerbulbs.com/product_detail.asp?prod=83 Mike |
looks like a bit of a con. still a filament lamp.
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Can`t see the point of them myself
![]() ![]() If your going to change the bulbs the best option would be leds ![]() |
actuall £5 ![]() it is about a brighter output without fitting hideous NAS spec ones Mike |
Ok still a tenner for 2
2 for £5 as it happens ![]() I know you dont need NAS spec lights for the LED bulbs - fact is the LED ones are £12 and im not 100% convinced they are better (and i dont like the NAS specs as mentioned) but £4.98 (actually) for the up rated ones maybe better way to go Mike |
That link of yours shows £9.95
Yes but it was only an example - wouldnt buy them from there couldnt really link to the shop ![]() |
ah ![]() |
red Defender Member Since: 11 Feb 2008 Location: Cornwall Posts: 76 ![]() ![]() ![]() |
Am I missing something here. I thought the light output of side lights had a limit and it was below brake light output and fog light output.
I have fitted additional high level LED lamps (just below the gutter) and wired them through a relay and switch to the side light output. Problem is they seem too bright and I get flashed as if ive left my fog light on. The plan with the new truck is to wire them as fog lights. Whats broken now ? |
Well its the age old Yes....but no!
Yes the output is technically 21watts...but the output can be "higher" eg: brighter in a number of ways, the filament is thicker and the gas in the bulb - other factors that dont apply to us like the reflector and lense. These bulbs apparently "respond" quicker when you press, giving a faster response - thus people behind get a better response time (i understand LED's also do this) and when they do light they shine brighter. The thing for me is the cheapest i can find the LED bulbs is £12 and these are £4.99 - but at the end of the day they are just bulbs. Think a little like the front bulbs. Mike |
They will tell us anything just to get a sale ![]() ![]() |
