![]() | Home > General & Technical (L663) > Gap Diagnostic Tool Activations for IID 4 tool + other items |
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197 ![]() ![]() ![]() |
exactly! so annoying that I am considering going back to original setting 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
Lonfred Member Since: 20 Sep 2024 Location: Barcelona Posts: 6 ![]() ![]() |
Hi,
Thanks for chairing your settings. What does this change do? MultiCAN-566 MHLastUserMode Last user memory mode disabled Last user memory mode enabled Does is remember the last driving mode? For example driving mode mud/ice will be remembered when starting car again? |
Hi,
this change remembers that I want to have auto start stop off ![]() 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
The_75th Member Since: 28 Apr 2023 Location: Devon Posts: 31 ![]() ![]() |
Wade Sensing...
...What might the differences be do y'all reckon? ![]() Click image to enlarge |
Dannymm Member Since: 28 Jun 2024 Location: Wiltshire Posts: 20 ![]() ![]() |
Yes you have to have all these 3 setting to match MultiCAN - 838 Speedo Market MultiCAN - 577 SpdoCalPercentScale MultiCAN -575 SpdoCalkmhOffset |
Brockmoor Howard Member Since: 12 Dec 2021 Location: antwerp Posts: 28 ![]() ![]() |
Hi Guys, has anybody info on what CCF modifications are needed for activating electronic active rear differential & torque vectoring by braking ?
Muehae Member Since: 17 Jun 2023 Location: Erding Posts: 27 ![]() ![]() |
have you retrofitted a rear locking diff?
As i understand this, it not just a software adjustment, but a real part which is needed... |
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 312 ![]() ![]() |
Of course, it would be unthinkable that we would have a sleeping rear differential available at the price it has. Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
Indeed, a lot of configurations are sleeping in the CCF.
I was told by professionals that the differential is activable to become electronic. I wonder what EUCD/MULTICAN number is connected to that activation. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2724 ![]() ![]() |
The locking differential is a different physical part, it has a solenoid and extra wiring etc. as well as the actual differential itself.
It can be added but is a lot more work than just software. Have a read of this thread to get an idea of what is involved: https://www.defender2.net/forum/topic78820.html |
Thank you for this valuable info.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3031 ![]() ![]() |
Have you tried this and did it work for you? When l tried it, l got various errors such as collision avoidance disabled and 2wd only available. l reset the settings and the faults disappeared. |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 75 ![]() ![]() |
Fellas the locking rear differential can be oem factory retrofitted. I did it on my 2020.
https://www.instagram.com/p/CPcL8nNlhLw/?u...gn=loading ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Has anyone found a way to set the Driver Assistance level (the steering wheel button on new models) to remember the user setting (like e.g. we have managed with start/stop)? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
