Home > General & Technical (L663) > Launch Control
Harty
Launch Control
1. Select sand mode
2. Put gear into D, then flick gear stick left to S1.
3. Hold break down with left foot
4. Push accelerator down fully
5. Release break pedal
Post #1036075 30th May 2024 11:45am
LR Nuts
That 'Trick' was first used in the Freelander 2, LR could not understand why clutches were burning out so quick.
Not the best use of your torque converter Sad
Post #1036082 30th May 2024 12:28pm
Harty
Completely agree. Only found about it recently. V rapid as a one off though.
Post #1036083 30th May 2024 12:30pm
lightning
Yes with most automatic transmissions you can select D, hold it on the brake and floor the accelerator then release the brake once the RPM stabilises
The vehicle should then take off like a rocket.
However l wouldn't recommend it. Not unless you have a stock of spare transmissions in your garage.
l imagine most new vehicles have some sort of safety interlock to prevent such abuse, maybe selecting "SAND" mode bypasses it on the Defender.
Post #1036086 30th May 2024 12:40pm
