![]() | Home > General & Technical (L663) > Launch Control |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
That 'Trick' was first used in the Freelander 2, LR could not understand why clutches were burning out so quick.
Not the best use of your torque converter ![]() |
Harty Member Since: 20 Feb 2021 Location: London Posts: 31 ![]() ![]() |
Completely agree. Only found about it recently. V rapid as a one off though.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3016 ![]() ![]() |
Yes with most automatic transmissions you can select D, hold it on the brake and floor the accelerator then release the brake once the RPM stabilises
The vehicle should then take off like a rocket. However l wouldn't recommend it. Not unless you have a stock of spare transmissions in your garage. l imagine most new vehicles have some sort of safety interlock to prevent such abuse, maybe selecting "SAND" mode bypasses it on the Defender. |
