Home > In Car Electronics > Power for dab aerial |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6595 |
The purple with green stripe is the one you want.
Black is negative Red/orange stripe is illumination 1988 90 Td5 NAS soft top 2015 D90 XS SW |
25th May 2024 3:49pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2203 |
Is there not a 12v output on the stereo harness usually dedicated for electric aerials but no reason why it wouldn't supply a dab aerial ?
25th May 2024 3:56pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 312 |
As mentioned above most stereos have a 12v output used for aerials or amp switching. In the ISO harness it is a blue wire.
25th May 2024 8:02pm |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 113 |
silly question guys but what sort of cable should get. Would 0.5mm cable be okay kind of like speaker wire its one of those jobs you just need a bit of advice on the bits to use
26th May 2024 7:25pm |
Wire size will depend on current draw. I can’t imagine that requires a lot of power, the rating of the fuse will be the clue, but most likely 0.5sqmm would be adequate over a short distance.
26th May 2024 7:32pm |
Thank you everyone finally got it working this morning. I use those cable connectors and some cable and then rap to all in black material tape then I really tidy job a bit of squeeze getting it all in
Click image to enlarge Click image to enlarge |
27th May 2024 11:23am |
