Home > In Car Electronics > Power for dab aerial
fatboyron
So I'm fitting a new Sony stereo into land rover and I've got a new dab aerial to replace the existing one but it needs power and thinking to piggyback off the cigar lighter which is got a black a purple and a red yellow stripe which colour is the power any help would be appreciate
Post #1035690 25th May 2024 2:23pm
Martin
Site Admin
The purple with green stripe is the one you want.
Black is negative
Red/orange stripe is illumination  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1035696 25th May 2024 3:49pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Is there not a 12v output on the stereo harness usually dedicated for electric aerials but no reason why it wouldn't supply a dab aerial ?
Post #1035698 25th May 2024 3:56pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
As mentioned above most stereos have a 12v output used for aerials or amp switching. In the ISO harness it is a blue wire.
Post #1035707 25th May 2024 8:02pm
fatboyron
silly question guys but what sort of cable should get. Would 0.5mm cable be okay kind of like speaker wire its one of those jobs you just need a bit of advice on the bits to use
Post #1035755 26th May 2024 7:25pm
Penfold_6290
Wire size will depend on current draw. I can’t imagine that requires a lot of power, the rating of the fuse will be the clue, but most likely 0.5sqmm would be adequate over a short distance.
Post #1035756 26th May 2024 7:32pm
fatboyron
Thank you everyone finally got it working this morning. I use those cable connectors and some cable and then rap to all in black material tape then I really tidy job a bit of squeeze getting it all in
Post #1035799 27th May 2024 11:23am
