Home > Maintenance & Modifications > Defender 2.2 sump plug size ?
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all,
I have been tasked with reinstating a friends landrover that’s sat a whilst, I’m very happy mechanically but the vehicle is a reasonable distance away from me so trying to make sure I take all that’s needed
So , the sump plug is it a straight forward bolt / spanner configuration ?
Or one of those fancy Allen keys / splined affairs ?
Once it’s been serviced and up n running and mot / valeted etc it will be for sale
It will be listed on here of course
It was registered new in the last 6months of defender manufacture , it’s a 90 pick up,
Went straight from the showroom to be professionally under body treated
Has had a sprinkling of Bowler bits added amongst other bits,
Best bit is it has roughly 15k on the clock from new
Possibly the nearest you will get to a “new” one ?
Watch this space Thumbs Up
Post #1034982 17th May 2024 7:37am
Ianh
Engine sump plug is a standard hex head. Comes with rubber sealing ring and should be replaced each oil change. Part number 1013938 , see part 3 https://www.lrworkshop.com/diagrams/land-r...ck_2.2tdci. And https://www.lrworkshop.com/parts/1013938
Torque 23 Nm / 17 lbf∙ft
Ps on the later 2.2 the oil filter is the metal canister type, not a paper one . https://www.lrworkshop.com/diagrams/land-r...er_2.2tdci part number LR104384
Engine Oil is a C1 due to DPF , Ford's WSS-M2C-934-B Standard. See https://www.defender2.net/forum/topic34176.html
Post #1034992 17th May 2024 9:49am
Daisy90
Cheers for that, I was a little surprised about a metal oil filter after having an earlier 2.4
Oils is correct grade also,
Ready to pack it up and get it doing on Monday
Cheers all
Post #1035007 17th May 2024 12:18pm
