Home > Maintenance & Modifications > Defender 2.2 sump plug size ? |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2098 |
Engine sump plug is a standard hex head. Comes with rubber sealing ring and should be replaced each oil change. Part number 1013938 , see part 3 https://www.lrworkshop.com/diagrams/land-r...ck_2.2tdci. And https://www.lrworkshop.com/parts/1013938
Torque 23 Nm / 17 lbf∙ft Ps on the later 2.2 the oil filter is the metal canister type, not a paper one . https://www.lrworkshop.com/diagrams/land-r...er_2.2tdci part number LR104384 Engine Oil is a C1 due to DPF , Ford's WSS-M2C-934-B Standard. See https://www.defender2.net/forum/topic34176.html |
17th May 2024 9:49am |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 |
Cheers for that, I was a little surprised about a metal oil filter after having an earlier 2.4
Oils is correct grade also, Ready to pack it up and get it doing on Monday Cheers all |
17th May 2024 12:18pm |
