Home > Maintenance & Modifications > Smaller Steering Wheel Recommendations
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Fitted extended seat rails which has helped me fit into my new puma however; for a little bit more room I want to fit a smaller steering wheel. Show me yours for inspiration.
Post #1033626 2nd May 2024 4:35pm
Ianh
Certainly for a Puma the ultimate in look, fit with original styling and quality the Startech is hard to beat. But it is circa £600 !!!
A very good alternative is the Momo Tuner in 350mm size at circa £200, the 320mm is too small if you want to see the dash dials.
Lots of posts and pictures on the forum of both, and other alternatives.
Ideally, for security, you would use an Optimill quick release boss plus swivel lock to fit. £325 well spent in my opinion.
Post #1033633 2nd May 2024 6:12pm
Phillywilly72
Thanks Ian. Never swapped a wheel before is it best to get a low profile boss to allow for the most legroom?
Post #1033646 2nd May 2024 7:38pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
If you’ve got the money to burn then a Startech fitted to an Optimill removable boss is very satisfying.
Post #1033649 2nd May 2024 7:59pm
Crash7
Momo Prototipo and Momo Mod 7 are both great wheels that come a few different finishes Thumbs Up
Post #1033650 2nd May 2024 8:00pm
Stacey007
Probably 5 years or more with the Startech option
Best mod to truck, you use it every time you drive the truck it just feels better / nicer to hold. Thick but not too thick.
Only issue I have (although its not an issue as I use a Ultra gauge for speed / revs) between certain speeds the actual rim covers the dials (I'm 6ft 2). However I just use the digital read out any way as I find its more accurate.
Post #1033714 3rd May 2024 12:52pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
I went with Momo Prototipo
Whatever you get, also invest in a removeable boss and lock from optimill. Makes for a good extra layer of security
Post #1033816 4th May 2024 7:28pm
