![]() | Home > Maintenance & Modifications > Smaller Steering Wheel Recommendations |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2232 ![]() ![]() |
Certainly for a Puma the ultimate in look, fit with original styling and quality the Startech is hard to beat. But it is circa £600 !!!
A very good alternative is the Momo Tuner in 350mm size at circa £200, the 320mm is too small if you want to see the dash dials. Lots of posts and pictures on the forum of both, and other alternatives. Ideally, for security, you would use an Optimill quick release boss plus swivel lock to fit. £325 well spent in my opinion. |
Phillywilly72 Member Since: 29 Apr 2024 Location: Wiltshire Posts: 77 ![]() ![]() ![]() |
Thanks Ian. Never swapped a wheel before is it best to get a low profile boss to allow for the most legroom?
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 167 ![]() ![]() ![]() |
If you’ve got the money to burn then a Startech fitted to an Optimill removable boss is very satisfying.
Crash7 Member Since: 21 Feb 2024 Location: South Posts: 36 ![]() ![]() |
Momo Prototipo and Momo Mod 7 are both great wheels that come a few different finishes
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Probably 5 years or more with the Startech option
Best mod to truck, you use it every time you drive the truck it just feels better / nicer to hold. Thick but not too thick. Only issue I have (although its not an issue as I use a Ultra gauge for speed / revs) between certain speeds the actual rim covers the dials (I'm 6ft 2). However I just use the digital read out any way as I find its more accurate. ![]() Click image to enlarge |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 ![]() ![]() ![]() |
I went with Momo Prototipo
Whatever you get, also invest in a removeable boss and lock from optimill. Makes for a good extra layer of security |
