Home > Maintenance & Modifications > Transfer Box Plugs
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Transfer Box Plugs
First time replacing the oils and noticed on tightening they seem to go in forever without much force. Should these plugs get tighter the further they go in? Also should they go to just flush with casing, I am afraid mine are going in too far!
Post #1033511 1st May 2024 1:08pm
May be a sign of it being previously over tightened, which is why the WSM states specific torque settings.
Equally, experienced hands know the correct torque close enough to nip up to where it should be and quickly and appropriately and comes with experience. KEEP CALM AND Drill ON
Post #1033539 1st May 2024 6:13pm
Phillywilly72
The plugs on the transfer box are 1/2 inch square, looks like they had a white thread lock added. Any comments on how far they should go?
Post #1033545 1st May 2024 6:49pm
Sorry I was thinking of the gearbox my mistake.
It’s probably not thread lock the white stuff, but remains of PTFE tape for sealing. (I use that).
30NM torque for filler and drain plug.
(Remove filler first).
Qty 2.4L of transfer box oil.
You can use GL4 or GL5 in the transfer box, gearbox must be GL4.
Diffs GL5.
You only need one or two winds of PTFE tape in the direction of the thread, on the clean threads, if you don’t use some you might have some weep once filled.
A little wire brush is ideal to gently clean the plug threads.
Hope that helps. Thumbs Up KEEP CALM AND Drill ON
Post #1033547 1st May 2024 7:02pm
