Home > Maintenance & Modifications > Transfer Box Plugs |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20156 |
May be a sign of it being previously over tightened, which is why the WSM states specific torque settings.
Equally, experienced hands know the correct torque close enough to nip up to where it should be and quickly and appropriately and comes with experience. NEVER SURRENDER! β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ Last edited by custom90 on 1st May 2024 8:04pm. Edited 1 time in total |
1st May 2024 7:13pm |
Phillywilly72 Member Since: 29 Apr 2024 Location: Wiltshire Posts: 44 |
The plugs on the transfer box are 1/2 inch square, looks like they had a white thread lock added. Any comments on how far they should go?
1st May 2024 7:49pm |
Sorry I was thinking of the gearbox my mistake.
Itβs probably not thread lock the white stuff, but remains of PTFE tape for sealing. (I use that). 30NM torque for filler and drain plug. (Remove filler first). Qty 2.4L of transfer box oil. You can use GL4 or GL5 in the transfer box, gearbox must be GL4. Diffs GL5. You only need one or two winds of PTFE tape in the direction of the thread, on the clean threads, if you donβt use some you might have some weep once filled. A little wire brush is ideal to gently clean the plug threads. Hope that helps. NEVER SURRENDER! β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
1st May 2024 8:02pm |
