![]() | Home > Technical > Defender won’t go above 50 |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1640 ![]() ![]() |
something wrong if it was faster before the work...
Djmdaniel Member Since: 16 Jun 2023 Location: Northamptonshire Posts: 12 ![]() ![]() ![]() |
Yes it was used to do about 80 max, any idea what could cause this? Thanks
alas no it could be any things. return to whomever did the work asap and give them chance to check it over
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2152 ![]() ![]() |
Is the transmission brake binding ? It would get pretty hot if it were.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
it in high i take it? Cheers
That’s an interesting idea JST, especially if the transfer box was in Low, the linkage not connected and the lever in high.
DJMdaniel , Have you been going through the gears double quick to get up to speed ? |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Did they forget to plug the air flow meter or the vacuum hose to the air box?
