Home > Technical > Defender won’t go above 50 |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1631 |
something wrong if it was faster before the work...
4th Apr 2024 7:42pm |
Djmdaniel Member Since: 16 Jun 2023 Location: Northamptonshire Posts: 12 |
Yes it was used to do about 80 max, any idea what could cause this? Thanks
4th Apr 2024 7:44pm |
alas no it could be any things. return to whomever did the work asap and give them chance to check it over
4th Apr 2024 8:11pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2100 |
Is the transmission brake binding ? It would get pretty hot if it were.
4th Apr 2024 9:08pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
it in high i take it? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
That’s an interesting idea JST, especially if the transfer box was in Low, the linkage not connected and the lever in high.
DJMdaniel , Have you been going through the gears double quick to get up to speed ? |
4th Apr 2024 9:32pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1654 |
Did they forget to plug the air flow meter or the vacuum hose to the air box?
5th Apr 2024 9:23pm |
