Home > Maintenance & Modifications > Headlight adjustment
Page 2 of 2 <12
ZeDefender
drewster wrote:
my question is what is the mesurment of a and b
For a Beetle, A is the distance on a wall (10 metres away) between the bright centres of the light pattern (the brightest part before the light slants up) and should be the same as the distance between the centres of the headlamps.
B should be the height from the ground to the centres of the headlamps minus 5 cm.
It's important that the horizontal part of the light pattern is below B (allowing for a bit of "light smear"
This was my mistake yesterday (I set the pattern centres at B).
Our Beetle-mechanic says this is how he does it and reckons it should be about the same for most cars.
BUT I reckon the lights on a Defender are so high up, they throw the light further forward in any event (this was my worry yesterday). I reckon my original lamps and bulbs were so dim, I never noticed before... Tell someone you love them today because life is short.
Post #100084 15th Nov 2011 2:42pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
feet and inches or cm and meeters lol i would like to know what the exact distance is
Post #100085 15th Nov 2011 2:47pm
ZeDefender
Rolling Eyes
I can get you started, since I did B again this morning - its 91 cm minus 5 cm = 86 cm OR 34 inches
10 metres = 33 feet
Oh God... I just can't do this any more Thud Tell someone you love them today because life is short.
Post #100088 15th Nov 2011 2:59pm
Chopperone
Run out of headlight adjustment- help
I recently bought some Led headlights from Boltonbits proper ones not cheap & nasty.
RDX headlights.
Having fitted them I used the original adjustment set up & didn't alter a thing; they were clearly high & to the right.
I readjusted them & then checked them at a mate's mot station.
They still weren't right so we adjusted them to the max - low & left & the mot tester said he would pass it (just).
I still think they are too high & could with going a bit more to the kerb....as occasionally I get the odd flash & they are great at lighting up big signs on the left of the road!
Obviously I could put even longer bolts in or fit a spacer that brings the lights down & to the left
OR is there another way?
Guy May your life be like toilet paper ; long & useful.
Post #606824 5th Mar 2017 7:55am
Page 2 of 2 <12
