Home > Maintenance & Modifications > Headlight adjustment
ZeDefender
Hi all Smile
Thanks to excellent advice from you lot, I bought some Philips Extreme Vision bulbs and fitted them with Crystal headlamps from Paddocks (ridiculously fast postage to Germany Thumbs Up )
Considering my 110 now lights up the road like "Crystal" Palace Razz I thought I should adjust them as correctly as possible.
I've done this on a 1974 Beetle where the dipped beam setting on a wall is (centre of brightest area) 5cm below bulb height at 5 metres. Trouble is, the lights on the 110 are almost twice as high Shocked and I'm worried about blinding people.
So... please can anyone tell me a "rule of thumb" for setting the headlights?
Matt Tell someone you love them today because life is short.
Post #99916 14th Nov 2011 4:59pm
Happyoldgit
Personally I'd have marked the beam on the wall with the vehicle positioned a know distance from it prior to doing anything - then you would have had some reference points to work to. As it is the best way would be to get them properly set up on a proper headlamp aligner. Steve.
http://forums.lr4x4.com
Post #99921 14th Nov 2011 6:03pm
ZeDefender
NOW you tell me Rolling Eyes
Actually I'm fairly sure they weren't well set to start with - probably part of the reason they seemed so pathetic.
I will get them set properly a.s.a.p. but the nearest TÜV is in Munich and it will be a week or more before I can get an appointment...
Cheers Tell someone you love them today because life is short.
Post #99923 14th Nov 2011 6:07pm
T1G UP
doesn't your defender have adjustable headlights?
Post #99924 14th Nov 2011 6:09pm
ZeDefender
er... if you mean the compensation dial on the dash, then yes but only down.
I adjusted them to be level today (with a screwdriver Smile ) but I would like to know what a reasonable height is for both.
Good idea though Thumbs Up - if they seem too high I can compensate for now until I get them done properly (now why didn't I think of that?) Whistle Tell someone you love them today because life is short.
Post #99925 14th Nov 2011 6:17pm
Re: Headlight adjustment
You're not going to be far wrong applying the same principle to a Defender. The difference in height between it and a Beetle is an insignificant proportion of your 5m test distance. Darren
Post #99926 14th Nov 2011 6:23pm
ZeDefender
Cheers Thumbs Up
Post #99941 14th Nov 2011 7:11pm
Dave-H
I just adjust mine to give me a nice 'spread' and then go for a drive.
If i get a flash or two from oncoming traffic i re adjust height and try again.
Keep doing until no-one oncoming seems bothered Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #99946 14th Nov 2011 7:26pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
The manual says for a quick adjustment:
Exterior Lighting - Headlamp Adjustment
General Procedures
1. NOTE: Check main beam alignment using beam setting
equipment. Should this not be available the beam can be
temporarily checked and adjusted as follows.
Position vehicle, unladen, on level ground with tyres correctly
inflated, approximately 4 metres from a wall or screen,
marked as illustrated below.
2. The beam centres 'A' [measure between centre of lights] are measured horizontally on the
vehicle and dimension 'B' vertically from the ground [height from ground to centre of headlamp is same on wall].
3. Switch on main beam and adjust setting, as necessary, BM52
Post #99951 14th Nov 2011 8:12pm
ZeDefender
General Procedures
Good - seems pretty much what I thought Smile
Post #99952 14th Nov 2011 8:18pm
spudfan
Ireland
As ZeDefender says,but with a picturefrom the workshop manual.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #100008 14th Nov 2011 11:16pm
ZeDefender
Don't know if I'm bonkers but my trimmer screws are at the bottom Confused
If I had fitted them the way they are in the picture, the towing adjustment would make them aim higher Shocked
Change in design? Tell someone you love them today because life is short.
Post #100025 15th Nov 2011 6:40am
spudfan
Ireland
Could well be. I took the diagram from a tdi manual to illustrate the wall settings. 1982 88" 2.25 diesel
Post #100063 15th Nov 2011 12:09pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
my question is what is the mesurment of a and b
Post #100072 15th Nov 2011 12:59pm
spudfan
Ireland
As far as I know it should be the same as on the vehicle. Any garage with light checking equipment will check them and adjust them if necessary for a small fee.I get mine done before a vehicle test. 1982 88" 2.25 diesel
Post #100079 15th Nov 2011 2:20pm
