Home > Maintenance & Modifications > Leak on rear Alloy
Tdatp1defender
Leak on rear Alloy
Hi All,
I'm new to owning a 1987 defender and have a leak on the outside of my wheel, I'm not 100% sure on the name of the parts but after some googling I believe( please correct me if I'm wrong) this is axel drive flange dust cap and the gasket behind could be a drive flange gasket?
Does anyone have any advise if I'm on the right track that changing these two items could be the fix? And if the parts are even called what I've googled!
Any help much appreciated
Thanks [/img]
Post #1028535 18th Mar 2024 7:22pm
Mdm
pictures will help folk identify the issue
Post #1028537 18th Mar 2024 7:30pm
Dinnu
Pic in his gallery.
Yes, drive flange or drive member.
I would start with the dust cap as those are vulnerable.
Btw, rim looks like is steel, not alloy, although steel is still an alloy Whistle 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1028584 19th Mar 2024 5:04am
Tdatp1defender
Thanks for the help!
Post #1028654 19th Mar 2024 4:20pm
NickMc
Don’t buy the cheap plastic type part and I’d check your axle breather isn’t blocked Thumbs Up
Post #1028714 19th Mar 2024 10:05pm
rustandoil
I'd give that a wash with some hot soapy water..... Let it dry you'd then see if its the cap or gasket leaking 😉
Post #1028725 20th Mar 2024 5:47am
