Home > Modifications & Maintenance (L663) > External LR OEM Box Install Question
def130natasha
United States 2016 Defender 130 Other SW Auto Bali Blue
We recently took delivery of our 130 Outbound. Love it. Thinking about adding the box on the right side. Question - does anyone sell the trim piece with pre drilled holes? I have enough tools and skill to do it myself but I’m also wise enough in my years to know it might be worth my time to purchase this (avoid the which drill bit and shape does it best activity).
Post #1021934 20th Jan 2024 8:40pm
LR Nuts
".... Thinking about adding the box on the right side...."
The side mount box ONLY fits on the right side of the vehicle.
Should you want it on the left side you have to mount it on a molle plate.
Post #1021940 20th Jan 2024 9:09pm
def130natasha
Correct. Right side. For this post we are talking about the right side. No molle plates.
Post #1021964 21st Jan 2024 1:11am
Moo
Ukraine
I think these would work but the 130 version.
https://www.powerfuluk.com/collections/new...3-110-pair Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1021995 21st Jan 2024 11:23am
LR Nuts
Moo mate,
on your link, at the bottom of page.....
Which Vehicles will this fit ?
This item WILL fit the Land Rover Defender L663 - 110 models only
This item WILL NOT fit the Land Rover Defender L663 90 or 130 models.
although they do make them for the 90, under a different listing.
I can NOT find any for the 130 ?
But Unwin track can be bought in longer lengths. Thumbs Up
Post #1022001 21st Jan 2024 12:04pm
chpsk8
United States
I bought a generic amazon special in black for my 110. When it arrived it came with a trim piece that was predrilled. It was also black.
I also bought a generic ladder for the other side, and it to came with a black predrilled trim piece.
It may be worth asking the supplier if it comes with that predrilled trim. The factory one doesn't, but the Alibaba/Express/Amazon versions do. It greatly improved the install time and effort. Both took less than 20 minutes to install.
Post #1022081 21st Jan 2024 8:29pm
def130natasha
Does anyone know what the standard part number is for the trim piece?
https://www.landleaping.com/oem-parts/land...dhcy1taGV2
I think this is right.
Post #1022515 26th Jan 2024 5:49am
def130natasha
LR178947 is the correct part number. Unsure if it's painted or not. Will find out.
Post #1022642 26th Jan 2024 9:27pm
