![]() | Home > Modifications & Maintenance (L663) > External LR OEM Box Install Question |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
".... Thinking about adding the box on the right side...."
The side mount box ONLY fits on the right side of the vehicle. Should you want it on the left side you have to mount it on a molle plate. ![]() Click image to enlarge |
def130natasha Member Since: 15 Jan 2024 Location: california Posts: 5 ![]() ![]() ![]() |
Correct. Right side. For this post we are talking about the right side. No molle plates.
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
I think these would work but the 130 version.
https://www.powerfuluk.com/collections/new...3-110-pair Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
Moo mate,
on your link, at the bottom of page..... Which Vehicles will this fit ? This item WILL fit the Land Rover Defender L663 - 110 models only This item WILL NOT fit the Land Rover Defender L663 90 or 130 models. although they do make them for the 90, under a different listing. I can NOT find any for the 130 ? But Unwin track can be bought in longer lengths. ![]() |
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 45 ![]() ![]() |
I bought a generic amazon special in black for my 110. When it arrived it came with a trim piece that was predrilled. It was also black.
I also bought a generic ladder for the other side, and it to came with a black predrilled trim piece. It may be worth asking the supplier if it comes with that predrilled trim. The factory one doesn't, but the Alibaba/Express/Amazon versions do. It greatly improved the install time and effort. Both took less than 20 minutes to install. |
Does anyone know what the standard part number is for the trim piece?
https://www.landleaping.com/oem-parts/land...dhcy1taGV2 I think this is right. |
LR178947 is the correct part number. Unsure if it's painted or not. Will find out.
