Home > Puma (Tdci) > Puma 2.2 engine transit compatibility
nikiviro
Slovakia 2015 Defender 110 Puma 2.2 SW Montalcino Red
I am buying a new engine for my Defender 2.2 Tdci. I have found a brand new engine for a Transit 2.2 RWD. I know that the oil sump on the Transit engine is different from the one on the Defender, so it will need to be changed. On the cylinder head of the new engine, there is a code K4 TEA 2.2 RWD-08, and on my engine, there is K4 TEA 2.2 RWD-11. Does anybody know what these codes mean and if they are compatible?
Can anyone tell if this Transit engine is compatible with a Defender 2.2?
Post #1020517 8th Jan 2024 1:48pm
Manlax
Kenya
I would like to know, if it worked well.?? I want to buy the same Engine for my Defender puma 2.2 of 2015. Did it perform.?
Post #1044817 4th Sep 2024 8:29pm
wyvern
Next Meridian changed their engine in Australia for a transit 2.2 engine when their piston broke ..
see here ..
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #1044840 4th Sep 2024 10:48pm
Manlax
Kenya
Congratulations so far, You have really brought a smile once again on me. Because I spent a lot of Money for the previous Engine by doing Engine Overhaul but yet didn't work. It ended up doing Engine Overspeeding and led to breakdown the Crankshaft and the block sleeves as well. I was giving up with my Defender. But through you, really I'm quite sure my Defender will wake-up once again. Then can I know the supplier of the Ford Engine 2.2 from SA.?
Post #1044961 5th Sep 2024 8:59pm
Manlax
Kenya
How about the Turbo, did you change it as well.??
Post #1044964 5th Sep 2024 9:08pm
