Home > Puma (Tdci) > 2.4 wont start in cold temperatures
Page 2 of 2 <12
I've found the threads I remembered, it was a different problem namely ice forming in the breather at very low temperatures resulting in significant oil leaks. See:
https://www.defender2.net/forum/post122135.html
https://www.defender2.net/forum/post8698.html
Searching for "webasto" will produce a huge selection of background reading for you!
Note original post edited to correct autocorrect error - "ice" had helpfully been changed to "use".
Post #1020342 6th Jan 2024 10:31pm
jf_est
Estonia 2007 Defender 90 Puma 2.4 SW Java Black
Super useful. Appreciate the tip/links, blackwolf. Thank you.
Post #1020359 7th Jan 2024 10:08am
jf_est
Managed to get her going today, a battery charge and some anti-gel additive seemed to do the trick.
When I plugged a trickle charger onto the battery it was reading around 11 volts, so imagine the cold motor and low voltage just meant it was too hard to get started.
I took the car on a gentle run to get some warmth into the motor and topped off the tank with arctic diesel this afternoon - so should be good. Thankfully, temperatures are getting above -10 this week, so should be a little less extreme.
Thanks again everyone for the suggestions!
Post #1020392 7th Jan 2024 4:09pm
MK
Also there are some sticky electrical pads to warm up fuel tanks and filters, batteries, oil sumps etc. Puma 110" SW
Post #1020401 7th Jan 2024 5:00pm
You may find a new battery is due, simple as that. They normally have a VERY long lifespan but eventually a new one can be beneficial.
My last battery lasted 12 years I think approx.
You’ll soon know, if the battery voltage keeps dropping low.
I’d think about a new one when convenient to buy, probably no longer be an issue again.
The super low temps always brings about more cold cranking amps required, which can sometimes be the final straw. WeWillWin🇬🇧🇺🇸
Post #1020437 7th Jan 2024 8:55pm
nicolas0505
France
hello
For the oil breather hose I put heating pipe insulation
The advantages of this product:
Protection of pipes against cold
Easy to put on, even on the elbows
Excellent insulating qualities
Prevents the formation of condensation
Delays the effects of the gel
Very good stability over time
Composition
Based on closed-cell synthetic rubber
Post #1020439 7th Jan 2024 8:57pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Old thread but worth reviving. Driving in the -30°C range is always a possibility here in Edmonton, Alberta Canada.
Get your glow plugs checked. They do fail. When I bought mine, all four were kaput. It came from a warm climate and nobody had noticed.
Run a fuel additive with an anti-gel component. Run the tank right down in the late fall so you don't have any lingering summer fuel in your tank.
Will it start after sitting in -30°C? Yup. I double glow and then it cranks really, really slowly for a second or two then "starts". Runs @#$% rough and the good lord only knows how much engine wear you are causing. So, if everything is up to snuff, it will start, but you would be crazy to do so in anything but an emergency.
I run two Webasto heaters, one for the coolant and one heating the cab. I start the coolant one with a remote and, once it gets going, it starts the cab heater. They run off a separate battery so they don't run down the starting battery. After 45 minutes, the cab is coolish with no visible breath -- remember, we're talking -30C, the cab is warm at other temps -- and the coolant gauge shows an almost fully warmed engine. It still cranks a little slow and takes a while for the oil light to go out (remember, -30°C). I plan on adding plug-in heating pads to the sump and underneath the batteries.
The Webastos are also on dash switches so I can turn them on while driving as well. The regular heater puts out great so no need for the auxiliary coolant heater but a 110 has a huge cab and I often cycle the auxiliary cab heater on and off (only when it's @#$% cold). The cab is then very warm, toasty actually. I do plan on having a fabric/clear partition made up to isolate the passenger cab from the load area to facilitate faster cab warm ups and reduce how often I use the aux cab heater.
The heated screen is an absolute must and I will be adding heated wiper blades before next winter.
Heated seats are not optional, full stop.
Also really cold batteries do not charge. The battery location is not ideal so it takes a good long run to recharge the batteries. Frequent short trips will run them down. If you don't have a battery heater, use a trickle charger when it is really cold.
Post #1059828 7th Feb 2025 4:56pm
jf_est
Great point, I should have updated the thread, but along with a local garage I discovered that the glow plugs weren't getting current - so it was unlikely they were doing anything at all, which would explain why it was so difficult to get going.
Also, I'm pretty convinced I need a stronger battery. The one I have currently works, but I'm sure fitting an upgraded lithium item would resolve any lingering cold start issues. My car is kept indoors in a garage, which protects it from the ice/snow, but not the cold.
Post #1060773 17th Feb 2025 4:06pm
jbcollier
I'm also adding a 12v-100w fuel filter heater.
It blows a lot of blue when descending a medium hill and very light throttle is applied. Throttle released, all clear. Fraction more throttle, clears up. This is only when temps hit -20°C and lower. Adding anti-gel helps a lot. Without anti-gel, cars behind disappear.
I thought I had low-temp mapping issues but I was talking with another Defender owner and his performs similar antics (300TDI) so it must be a quirk of gelling fuel.
Post #1060774 17th Feb 2025 4:23pm
Page 2 of 2 <12
