Home > Puma (Tdci) > 2.4 wont start in cold temperatures |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17380 |
I've found the threads I remembered, it was a different problem namely ice forming in the breather at very low temperatures resulting in significant oil leaks. See:
https://www.defender2.net/forum/post122135.html https://www.defender2.net/forum/post8698.html Searching for "webasto" will produce a huge selection of background reading for you! Note original post edited to correct autocorrect error - "ice" had helpfully been changed to "use". Last edited by blackwolf on 7th Jan 2024 9:32am. Edited 1 time in total |
6th Jan 2024 9:31pm |
jf_est Member Since: 12 Nov 2023 Location: Tallinn Posts: 25 |
Super useful. Appreciate the tip/links, blackwolf. Thank you.
7th Jan 2024 9:08am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2415 |
Also there are some sticky electrical pads to warm up fuel tanks and filters, batteries, oil sumps etc. Puma 110" SW
7th Jan 2024 4:00pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
You may find a new battery is due, simple as that. They normally have a VERY long lifespan but eventually a new one can be beneficial.
My last battery lasted 12 years I think approx. You’ll soon know, if the battery voltage keeps dropping low. I’d think about a new one when convenient to buy, probably no longer be an issue again. The super low temps always brings about more cold cranking amps required, which can sometimes be the final straw. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
7th Jan 2024 7:55pm |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 79 |
hello For the oil breather hose I put heating pipe insulation The advantages of this product: Protection of pipes against cold Easy to put on, even on the elbows Excellent insulating qualities Prevents the formation of condensation Delays the effects of the gel Very good stability over time Composition Based on closed-cell synthetic rubber |
7th Jan 2024 7:57pm |
