![]() | Home > Modifications & Maintenance (L663) > After market Side Carrier box |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
Looks good. Just need some chunky tyres.
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 45 ![]() ![]() |
Very cool. I like that Defender logo. I didn't scroll far enough and thought that looked very familiar. I have the same logo on my aftermarket tire cover! Good use of it on the box.
My aftermarket box came with a little logo that was a caricature of a Defender. It was pretty cool, but fell off pretty quick. I hoped on Aliexpress and got three different versions of the factory logo as replacements. Kind of a pita to find the correct size since it's a touch smaller. Ended up with the right one though. I like those molle plates as well. Very useful and rugged looking. Nice job. |
BadgerWaz Member Since: 15 Jul 2024 Location: Somewhere else Posts: 110 ![]() ![]() |
I've found your old post via searching, for the side mounted gear carrier, do you think this could be fitted on either side without modifying?
I did wonder if LR don't want it fitting near to cyclists if this is deeper than the ladders are? I won't need the ladders, and a having a side box on either side would be useful for our wetsuits to drip out of if it'c possible to have two?? |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 156 ![]() ![]() |
It’s delivery van wing mirrors I worry about when cycling, not Defender ear mufflers. I can vouch for the pain and damage wing mirrors can do!
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 234 ![]() ![]() |
I understand the reason why you moved the box on the molle plate. However I found it being a very expensive solution.
Also I found that the side ladder is kind of not great to use. I have mine at the back. |
