Home > Modifications & Maintenance (L663) > After market Side Carrier box
LR Nuts
I've been choppin'n'changin things around on the exterior rear.
I have a Genuine ladder, currently mounted on the left (N/S) ... LR states it can be mounted on either side.
I have an aftermarket Side Carrier box ... LR states this can ONLY be mounted on the right (O/S)
Further I have the Molle plates for both sides.
Now I have fitted the RH Molle plate and modified the ladder to fit over it. (just drill two new holes for upper mounting)
Now by luck I got hold of a Molle plate LH Version 3, which has pre-drilled holes to mount the Side Carrier box. But this is removable as it covers the whole of the Molle plate.
In addition I removed the LR oval badge from the Side Carrier box and replaced it with the insert of an aftermarket DEFENDER logo, from a rear wheel cover.
Looks very different Very Happy
Post #1019013 22nd Dec 2023 5:01pm
Moo
Ukraine
Looks good. Just need some chunky tyres. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1019016 22nd Dec 2023 5:18pm
chpsk8
United States
Very cool. I like that Defender logo. I didn't scroll far enough and thought that looked very familiar. I have the same logo on my aftermarket tire cover! Good use of it on the box.
My aftermarket box came with a little logo that was a caricature of a Defender. It was pretty cool, but fell off pretty quick. I hoped on Aliexpress and got three different versions of the factory logo as replacements. Kind of a pita to find the correct size since it's a touch smaller. Ended up with the right one though.
I like those molle plates as well. Very useful and rugged looking. Nice job.
Post #1019039 22nd Dec 2023 11:07pm
BadgerWaz
I've found your old post via searching, for the side mounted gear carrier, do you think this could be fitted on either side without modifying?
I did wonder if LR don't want it fitting near to cyclists if this is deeper than the ladders are?
I won't need the ladders, and a having a side box on either side would be useful for our wetsuits to drip out of if it'c possible to have two??
Post #1063841 25th Mar 2025 2:56pm
stevemfr
France
if it does have to do with cyclists, LR does not give a ship about the cyclist in countries with LHD vehicles - the mounting options are exactly the same.
And I don't understand why either...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1063983 26th Mar 2025 11:02pm
Moo
Ukraine
It’s delivery van wing mirrors I worry about when cycling, not Defender ear mufflers. I can vouch for the pain and damage wing mirrors can do! Twisted Evil Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1063990 26th Mar 2025 11:39pm
Crazymind
I understand the reason why you moved the box on the molle plate. However I found it being a very expensive solution.
Also I found that the side ladder is kind of not great to use. I have mine at the back.
Post #1064000 27th Mar 2025 8:44am
