Home > In Car Electronics > Factory Heated Seat Wiring Plug
Ambo_Chris
United Kingdom 2013 Defender 110 Puma 2.2 USW Baltic Blue
Hi all,
The male plug on my passenger heated seat is missing, I have sourced a replacement (YPC111740) does anyone have any tips for getting the pins in the plug? It is made by TE Connectivity.
Cheers!
 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
2000 Beige Discovery 2 Td5 GS (Long gone)
1994 Red (various) 90 300tdi CSW (Long gone)
Post #1015424 17th Nov 2023 12:16pm
Martin
Site Admin
The green seals should both be 'captive' in the terminal, but the part which holds the seal is broken off your terminal (compare the two). Ideally you'd change the terminal, but your replacement has pattern seals so probably pattern terminals which don't normally fit very well Sad
I've knocked up a test wire to show you:
With the connector body clip side up, the spring and flag on the terminal should be facing up as well. Then just push the terminal in, it should go 'click'.
Make sure the terminal is straight on the wire before fitting, if it's bent out of line you might struggle to get it home.
Do that with both, then inside the connector:
Above terminal 2, there should be a small grey clip visible (circled). With a small screwdriver or straightened paperclip, push this in gently, then flick it to the right as arrrow. This locks the terminals in.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1015426 17th Nov 2023 12:37pm
Ambo_Chris
wow, thanks for the super detailed reply, will have a go and let you know how I get on! 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
Post #1015430 17th Nov 2023 1:08pm
