![]() | Home > In Car Electronics > Factory Heated Seat Wiring Plug |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6644 ![]() ![]() ![]() |
The green seals should both be 'captive' in the terminal, but the part which holds the seal is broken off your terminal (compare the two). Ideally you'd change the terminal, but your replacement has pattern seals so probably pattern terminals which don't normally fit very well
![]() I've knocked up a test wire to show you: ![]() Click image to enlarge With the connector body clip side up, the spring and flag on the terminal should be facing up as well. Then just push the terminal in, it should go 'click'. Make sure the terminal is straight on the wire before fitting, if it's bent out of line you might struggle to get it home. Do that with both, then inside the connector: ![]() Click image to enlarge Above terminal 2, there should be a small grey clip visible (circled). With a small screwdriver or straightened paperclip, push this in gently, then flick it to the right as arrrow. This locks the terminals in. ![]() ![]() |
Ambo_Chris Member Since: 01 Dec 2021 Location: South West Posts: 31 ![]() ![]() ![]() |
wow, thanks for the super detailed reply, will have a go and let you know how I get on! 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
