![]() | Home > Tdi > Defender 90 300 TDI |
UROMP Member Since: 19 Oct 2014 Location: Pembrokeshire Posts: 8 ![]() ![]() ![]() |
Would this battery be a good replacement for my 1998 300 TDI.
EXIDE PREMIUM 12v Capacity 75Ah CCA (EN) 630A Wet £84.78 |
IIRC and it has been a while. The biggest battery that can fi tin to the box is a 663 which is a 110Ah battery. Cannot go wrong in winter with a 110Ah and 750 CCA under the seat.
Many thanks for your replies.
julian Member Since: 17 Feb 2017 Location: Devon Posts: 156 ![]() ![]() ![]() |
I'd like to think you're sorted by now, but, for anyone else reading later, these also fit -
https://www.tayna.co.uk/car-batteries/yuasa/ybx5020/ They are a fair bit longer than the 663 but do fit. One point that I can't confirm is if the stock tie down will work. I'm not sure if the slots in the bottom of the battery tray are far enough apart. I'm pretty sure they are (from looking at mine) but as I've lost my j bar things currently, I can't say with absolute certainty. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
019 code batteries. Lead acid in older vehicles as they do not charge high enough to keep newer type batteries topped up. 1982 88" 2.25 diesel
