Home > Tdi > Defender 90 300 TDI
UROMP
Wales 1998 Defender 90 300 Tdi HT Coniston Green
Defender 90 300 TDI
Would this battery be a good replacement for my 1998 300 TDI.
EXIDE PREMIUM
12v
Capacity 75Ah
CCA (EN) 630A
Wet
£84.78
Post #1014525 9th Nov 2023 10:21am
TomB8
United Kingdom 1994 Defender 110 300 Tdi HT Arles Blue
Sure, if it is the right dimension etc. usually there's a number on your existing battery, like 096 that is a code for the dimensions and which side + and - are on. Just buy one with the same number as you have and it'll be ok.
Post #1014576 9th Nov 2023 7:25pm
geobloke
IIRC and it has been a while. The biggest battery that can fi tin to the box is a 663 which is a 110Ah battery. Cannot go wrong in winter with a 110Ah and 750 CCA under the seat. Thumbs Up
Post #1014586 9th Nov 2023 7:51pm
UROMP
Many thanks for your replies.
Post #1014591 9th Nov 2023 8:20pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
I'd like to think you're sorted by now, but, for anyone else reading later, these also fit -
https://www.tayna.co.uk/car-batteries/yuasa/ybx5020/
They are a fair bit longer than the 663 but do fit.
One point that I can't confirm is if the stock tie down will work. I'm not sure if the slots in the bottom of the battery tray are far enough apart. I'm pretty sure they are (from looking at mine) but as I've lost my j bar things currently, I can't say with absolute certainty.
Post #1023480 3rd Feb 2024 6:55pm
spudfan
Ireland
019 code batteries. Lead acid in older vehicles as they do not charge high enough to keep newer type batteries topped up. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1024210 10th Feb 2024 2:19pm
