Home > General & Technical (L663) > Activating ACC, ATPC, TR2 Auto, Park Assist, wheel size etc
Page 6 of 11 <123 ... 567 ... 91011>
lightning
l guess you get what you pay for. GAP tool is very good indeed, user interface superb, emails are always answered.
However if all you want to do is turn off the stop/start and activate a few features then l imagine an $99 tool is an attractive option.
One good thing with the GAP tool is, it saves your original CCF file so if you do make a mess of things or lose the connection while downloading you can always default back to the original software
Post #1015503 18th Nov 2023 10:30am
DefenderMidlands
The gap tool is definately easier to use but the jet pro software allows you to make a backup and restore the same and does give the option to activate acc, atpc and tr2 auto plus all the other activations you can do with the gap tool for $99 MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1015513 18th Nov 2023 11:17am
verrilli
United States
I got past the login problems with help from Gary at autosvs. Now when trying to activate ACC with script 17, I get "module not supported" error. If I try script 18, I get errors during the CCF write.
I also get errors during CCF write with script 1, start/stop memory.
Any suggestions? I wrote to Gary but I guess it's his night time.
Post #1015568 18th Nov 2023 7:45pm
ckamps
United States
Nicofender wrote:
Better get a cheap windows laptop with rj45. I know there were some problems in the past with that kind of software on macs. I would recommend not to adapter anything. Just think about a connection issue during uploading CCF changes.
USB C ethernet adapter works fine as well from my Windows laptop. Generally, a pretty burned in technology. 2021 D90 Pangea First Edition
2022 D110 X-Dynamic HSE Eiger Grey
Post #1015580 18th Nov 2023 9:09pm
DefenderMidlands
It sounds like it is probably your Ethernet connection MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1015582 18th Nov 2023 9:34pm
lightning
lf you're using the cheap tool l suppose you could research all the activations and then do them in the 72 hours of use that you pay for.
Make sure everything is working before your time is up.
Post #1015641 19th Nov 2023 2:55pm
verrilli
United States
I was able to get ACC enabled with the JET PRO tool. It took some work. First I tried with a cable that I already had used for an F series BMW. This did not work. I was getting write errors and Module not supported.
I ordered a new cable but in the meantime, my license expired.
So I tried with the new cable, new license and different laptop. This time it worked.
I was not able to get the "Remember Stop/Start setting" to work.
The Remote Release Tailgate did work.
I enabled Tow Assist 2 but haven't tried it yet. I don't know if it took
I already have the offroad package which includes ATPC2, configurable TR, etc
Is there anything else that I should do while I have the license? Is there an improved lane keeping function?
BTW, Gary at Autosvs said he would refund my second license since I was not successful with the first one. Many thanks!
Post #1016029 22nd Nov 2023 5:43pm
DefenderMidlands
Could try park assist / auto parking script?
Stop start should work by modifying
MultiCAN-566 MHLastUserMode = Enabled MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1016032 22nd Nov 2023 5:57pm
DefenderMidlands
Possible park assist settings
Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1016033 22nd Nov 2023 5:58pm
DefenderMidlands
I bought this cable and had no issues using it
Post #1016035 22nd Nov 2023 6:00pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Have you managed to get park assist to work? Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1016045 22nd Nov 2023 6:34pm
DefenderMidlands
No I didn’t have time to try it in the 72hrs of the licence but Gary at autosvs reckoned it should work.
I only enabled atpc and tr2 auto MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1016046 22nd Nov 2023 6:38pm
Hairy Dan
Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1016050 22nd Nov 2023 6:43pm
blancaster69
United States
I was able to get ACC, Dynamic (with red lights but no red dash), and tried "Remember Stop/Start setting" as well this morning. I also didn't think stop / start worked because the button didn't light up after everything else did. I'm not sure though, because even though the button wasn't lit I did notice where it normally show the A symbol with "off" listed below it, it showed the A symbol with a line through it and the engine never shut off. Can anyone else confirm? 22 Defender 110 X-Dynamic SE
17 RRS V-8 Supercharged Dynamic / Loire Blue / (Espresso/Almond/Ivory) / Zebrano
11 RRS HSE Lux / Galway Green / Almond / Anigre
08 RRS SC / Zermatt Silver / Ebony / Zebrano |
01 RR / Holland & Holland / Tintern Green
Post #1016057 22nd Nov 2023 7:22pm
verrilli
United States
Thanks for the info.
I checked and this is Enabled but it still doesn't remember the stop/start setting. I also tried the script.
I enabled Dynamic Mode. I see the choice on the terrain menu. Not sure what else to check for.
I tried enabling the Park assist. I don't get any errors. I'm not sure what to check for to see if it's working. I don't see any additional selections in the menus.
Post #1016061 22nd Nov 2023 7:34pm
