![]() | Home > General & Technical (L663) > Activating ACC, ATPC, TR2 Auto, Park Assist, wheel size etc |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 243 ![]() ![]() |
The gap tool is definately easier to use but the jet pro software allows you to make a backup and restore the same and does give the option to activate acc, atpc and tr2 auto plus all the other activations you can do with the gap tool for $99 MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
verrilli Member Since: 23 Aug 2023 Location: North Carolina Posts: 9 ![]() ![]() |
I got past the login problems with help from Gary at autosvs. Now when trying to activate ACC with script 17, I get "module not supported" error. If I try script 18, I get errors during the CCF write.
I also get errors during CCF write with script 1, start/stop memory. Any suggestions? I wrote to Gary but I guess it's his night time. |
ckamps Member Since: 04 Jul 2023 Location: Oregon Posts: 43 ![]() ![]() |
USB C ethernet adapter works fine as well from my Windows laptop. Generally, a pretty burned in technology. 2021 D90 Pangea First Edition 2022 D110 X-Dynamic HSE Eiger Grey |
It sounds like it is probably your Ethernet connection MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2945 ![]() ![]() |
lf you're using the cheap tool l suppose you could research all the activations and then do them in the 72 hours of use that you pay for.
Make sure everything is working before your time is up. |
I was able to get ACC enabled with the JET PRO tool. It took some work. First I tried with a cable that I already had used for an F series BMW. This did not work. I was getting write errors and Module not supported.
I ordered a new cable but in the meantime, my license expired. So I tried with the new cable, new license and different laptop. This time it worked. I was not able to get the "Remember Stop/Start setting" to work. The Remote Release Tailgate did work. I enabled Tow Assist 2 but haven't tried it yet. I don't know if it took I already have the offroad package which includes ATPC2, configurable TR, etc Is there anything else that I should do while I have the license? Is there an improved lane keeping function? BTW, Gary at Autosvs said he would refund my second license since I was not successful with the first one. Many thanks! |
Could try park assist / auto parking script?
Stop start should work by modifying MultiCAN-566 MHLastUserMode = Enabled MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
Possible park assist settings
Activate Park Assist EUCD-059 Parking Assistance Standard: Without Parking Assistance Change to: PDC (Front, Rear) - Parking (Parallel, Exit) EUCD-099 Park Assist Camera Standard: Without Park Assist Camera Change to: With Park Assist Camera EUCD-140 Pdcautoactivationmenu Standard: Not supported Change to: With PDC Auto Activation menu MultiCAN-469 PDCAutoActivation Standard: Not Supported Change to: Default OFF configurable MultiCAN-500 PDCBtnFCIM Standard: Not supported Change to: Fitted MultiCAN-602 PDC Standard: PDC not fitted Change to: 10 Channel fitted ( Park Assist) MultiCAN-786 Park Assist Standard: Not Fitted Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears) MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
I bought this cable and had no issues using it
![]() Click image to enlarge MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
Have you managed to get park assist to work? Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
No I didn’t have time to try it in the 72hrs of the licence but Gary at autosvs reckoned it should work.
I only enabled atpc and tr2 auto MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
blancaster69 Member Since: 08 Nov 2023 Location: Birmingham Posts: 7 ![]() ![]() |
I was able to get ACC, Dynamic (with red lights but no red dash), and tried "Remember Stop/Start setting" as well this morning. I also didn't think stop / start worked because the button didn't light up after everything else did. I'm not sure though, because even though the button wasn't lit I did notice where it normally show the A symbol with "off" listed below it, it showed the A symbol with a line through it and the engine never shut off. Can anyone else confirm? 22 Defender 110 X-Dynamic SE 17 RRS V-8 Supercharged Dynamic / Loire Blue / (Espresso/Almond/Ivory) / Zebrano 11 RRS HSE Lux / Galway Green / Almond / Anigre 08 RRS SC / Zermatt Silver / Ebony / Zebrano | 01 RR / Holland & Holland / Tintern Green |
Thanks for the info. I checked and this is Enabled but it still doesn't remember the stop/start setting. I also tried the script. I enabled Dynamic Mode. I see the choice on the terrain menu. Not sure what else to check for. I tried enabling the Park assist. I don't get any errors. I'm not sure what to check for to see if it's working. I don't see any additional selections in the menus. |
