Home > Puma (Tdci) > turbo defender puma 2007
pauli89
Ireland 2007 Defender 90 Puma 2.4 HT Java Black
guys,
nasty whistle coming from my turbo. Been told it needs to be replaced! Need to find the plate on it to get the number to see if it can be replaced with a transit turbo? can anyone help on this.
Post #97788 2nd Nov 2011 8:35pm
fekete
Read this it may help
http://www.defender2.net/forum/topic5115.html?highlight=turbo NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #97792 2nd Nov 2011 8:41pm
pauli89
thanks had a read but have been told by land rover that it needs to be replaced,,,
need to get at plate with part number on it now, to order from some one who aint tryin to rob me.
Post #97800 2nd Nov 2011 9:01pm
fekete
That's why there called the stealer Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #97802 2nd Nov 2011 9:05pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
http://www.ebay.co.uk/itm/FORD-TRANSIT-2-4...0688006913
That is the correct part number, by the way: 6C1Q6K682EN
Thumbs Up
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #97814 2nd Nov 2011 9:55pm
pauli89
thanks a million for that. is that the part number for the lnd rover turbo or the transit. have been told that the landi 1 must start with a 7 to be able to replace it with a transit 1
Post #97832 2nd Nov 2011 11:59pm
MK
OE number is LR021013 Thumbs Up Puma 110" SW
Post #97862 3rd Nov 2011 9:34am
szracer
Well, all I know is that having done a search for a replacement turbo on a turbo suppliers website,
http://www.btnturbo.com/parts/model/landrover/defender.aspx
that was the part number listed for a 2007-on 2.4 tdci Defender. Can't see why the Defender would use a different turbo to the Transit one. It's the same engine assembly, after all. But, don't hold me responsible.... Whistle
2005 Ducati ST3
1954 Sunbeam S8
Post #97865 3rd Nov 2011 9:46am
dgardel
Italy
Turbos are the same!!!
Installed a transit turbo on a Mate's Puma two months ago: perfect fit (and same numbers stamped on the turbo case).
Daniele Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #97866 3rd Nov 2011 9:53am
whip
France 2007 Defender 110 Puma 2.4 SW Alpine White
hi
is it necessary to replace it? can not you fix it?
Post #97886 3rd Nov 2011 12:46pm
Landyash
England 2007 Defender 110 Puma 2.4 DCPU Stornoway Grey
Hi like dgardel says there are the same,because I have fitted a Defender one On my Transit van;)You just need to Change the plastic elbow two 10 mill bolts.
Make sure it's off the 140 model Transit;)Wink
cheers Ash
Post #98025 4th Nov 2011 9:14am
spudfan
Ireland
They say that frequent oil changes together with good quality oil really benefit a turbo. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #98100 4th Nov 2011 5:54pm
