Home > Puma (Tdci) > turbo defender puma 2007 |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Read this it may help
http://www.defender2.net/forum/topic5115.html?highlight=turbo NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
2nd Nov 2011 8:41pm |
pauli89 Member Since: 02 Nov 2011 Location: dublin Posts: 3 |
thanks had a read but have been told by land rover that it needs to be replaced,,,
need to get at plate with part number on it now, to order from some one who aint tryin to rob me. |
2nd Nov 2011 9:01pm |
That's why there called the stealer NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
2nd Nov 2011 9:05pm |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 |
http://www.ebay.co.uk/itm/FORD-TRANSIT-2-4...0688006913
That is the correct part number, by the way: 6C1Q6K682EN 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
2nd Nov 2011 9:55pm |
thanks a million for that. is that the part number for the lnd rover turbo or the transit. have been told that the landi 1 must start with a 7 to be able to replace it with a transit 1
2nd Nov 2011 11:59pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
OE number is LR021013 Puma 110" SW
3rd Nov 2011 9:34am |
Well, all I know is that having done a search for a replacement turbo on a turbo suppliers website,
http://www.btnturbo.com/parts/model/landrover/defender.aspx that was the part number listed for a 2007-on 2.4 tdci Defender. Can't see why the Defender would use a different turbo to the Transit one. It's the same engine assembly, after all. But, don't hold me responsible....
3rd Nov 2011 9:46am |
Turbos are the same!!!
Installed a transit turbo on a Mate's Puma two months ago: perfect fit (and same numbers stamped on the turbo case). Daniele Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Nov 2011 9:53am |
whip Member Since: 17 Sep 2010 Location: haute savoie, Alpes Posts: 18 |
hi
is it necessary to replace it? can not you fix it? |
3rd Nov 2011 12:46pm |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 286 |
Hi like dgardel says there are the same,because I have fitted a Defender one On my Transit van;)You just need to Change the plastic elbow two 10 mill bolts.
Make sure it's off the 140 model Transit;) cheers Ash |
4th Nov 2011 9:14am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4655 |
They say that frequent oil changes together with good quality oil really benefit a turbo. 1982 88" 2.25 diesel
4th Nov 2011 5:54pm |
