Home > Maintenance & Modifications > 110 CSW rear seat back - bolt removal on trim?
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi,
I’ve removed my 4 inward rear seats in the back.
The seat backs slide off the bolts on the side trim when loosened (fixes to the capping).
Question is will the nuts drop off if I take these out completely:- do not look easily put back.
Was thinking of installing some cargo track and using the existing nuts/fixings (only for light stuff)
For a Sunday decided to leave out any nut innuendo.
Thanks
Rob
Post #1013065 29th Oct 2023 9:39am
donmacn
Disclaimer - my car is a 1994. However if I understand you right you’re talking about the bolts that go through the trim and capping and go into nuts which are welded onto rectangular captive plates.
There are holes on the underneath of the capping to get a couple of fingers in to slide the nut into place, or to capture it when you’re removing something. It’s not “easy” sometimes, but not the most technical thing.
I tried to find a part number and pics, but failed miserably on the mobile device I’m using. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1013071 29th Oct 2023 10:23am
