Home > Maintenance & Modifications > 110 CSW rear seat back - bolt removal on trim? |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1850 |
Disclaimer - my car is a 1994. However if I understand you right you’re talking about the bolts that go through the trim and capping and go into nuts which are welded onto rectangular captive plates.
There are holes on the underneath of the capping to get a couple of fingers in to slide the nut into place, or to capture it when you’re removing something. It’s not “easy” sometimes, but not the most technical thing. I tried to find a part number and pics, but failed miserably on the mobile device I’m using. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
29th Oct 2023 10:23am |
