Home > Maintenance & Modifications > Defender subwoofer installation |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 236 |
Nice, how does it sound? 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
28th Oct 2023 3:46pm |
sasdiscos Member Since: 22 Jul 2023 Location: UK Posts: 155 |
Not tested yet. If the suns out tomorrow I might get it test wired and see if I’ve wasted my time.
Steve. |
28th Oct 2023 5:46pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
That does look ‘factory’ so let’s hope it performs well 👍 |
28th Oct 2023 5:47pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
I have a low-profile sub mounted to the back of the cubby, it's been bugging me forever.
Funnily enough, I went to see the audio shop guy to do something like yours, will post some pics when he's done. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
28th Oct 2023 7:08pm |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 |
Hi, that looks a very neat job you’ve done there, have you put any Dynamat on the internal door skin? If not I can highly recommend adding some, look forward to hearing your findings when it’s connected cheers Paul
29th Oct 2023 9:38am |
Thanks Paul,
I’ve ordered some from eBay and some grey leather. I’m going to retrieve it all. Clean it up and spray the grille. I planned on sealing up the rear door and then sealing the new door card to the door with foam stripping. I didn’t get a chance to test it today as it’s been raining and I’ve ended up in the pub. Steve. |
29th Oct 2023 2:29pm |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 72 |
Here is my experience with acoustic insulation. Ripped the car apart numerous times. Stuffed in every conceivable place.
https://www.freel2.com/forum/topic33026.html I actually did as much research on Defenders as I could find to get your experience. Visitor - Freelander owner |
30th Oct 2023 2:13am |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80 |
Hi
what is the diameter of the speakers why not choose just one but with a larger diameter? |
31st Oct 2023 4:18pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 487 |
Hope it sounds better than it does in a Discovery, Land Rover definitley needed more acoustic training back then!
1st Nov 2023 11:33am |
They are not standard lr subs
1st Nov 2023 5:54pm |
Its the poorly designed enclosure even Alexa has more bass
2nd Nov 2023 9:47am |
