![]() | Home > Maintenance & Modifications > Defender subwoofer installation |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 236 ![]() ![]() |
Nice, how does it sound? 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
sasdiscos Member Since: 22 Jul 2023 Location: UK Posts: 155 ![]() ![]() |
Not tested yet. If the suns out tomorrow I might get it test wired and see if I’ve wasted my time.
Steve. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
That does look ‘factory’ so let’s hope it performs well 👍 |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
I have a low-profile sub mounted to the back of the cubby, it's been bugging me forever.
Funnily enough, I went to see the audio shop guy to do something like yours, will post some pics when he's done. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 ![]() ![]() ![]() |
Hi, that looks a very neat job you’ve done there, have you put any Dynamat on the internal door skin? If not I can highly recommend adding some, look forward to hearing your findings when it’s connected
Thanks Paul,
I’ve ordered some from eBay and some grey leather. I’m going to retrieve it all. Clean it up and spray the grille. I planned on sealing up the rear door and then sealing the new door card to the door with foam stripping. I didn’t get a chance to test it today as it’s been raining and I’ve ended up in the pub. Steve. |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 73 ![]() ![]() |
Here is my experience with acoustic insulation. Ripped the car apart numerous times. Stuffed in every conceivable place.
https://www.freel2.com/forum/topic33026.html I actually did as much research on Defenders as I could find to get your experience. Visitor - Freelander owner |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80 ![]() ![]() |
Hi
what is the diameter of the speakers why not choose just one but with a larger diameter? |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 492 ![]() ![]() |
Hope it sounds better than it does in a Discovery, Land Rover definitley needed more acoustic training back then!
They are not standard lr subs
Its the poorly designed enclosure even Alexa has more bass
