Home > Puma (Tdci) > Help - fuel cap problem |
Shropshirelad Member Since: 28 Aug 2023 Location: Shresbury Posts: 20 |
Bloody thing!! What do I do now, can’t get it open!!
Click image to enlarge |
8th Oct 2023 12:22pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1947 |
If taking the hose off make sure you give it a good clean first and have a thick plastic bag to cover the opening and tape it tight so no debris can get into the tank.
It looks like the red bit should extend pins that engage with the teeth in the white bit in the pipe to allow it to rotate anti clockwise. So you need a bit of circa 2-3mm thick rectangle flat steel bar to slot into an upper and lower tooth recess to enable you to rotate , using pliers as a handle. You may have a wood chisel that would be the right dimensions. |
8th Oct 2023 12:54pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4636 |
You could undo the filler hose neck clip and push the filler hose to one side with a bag over it. Just make sure the fuel in the tank is below the neck! Have a look at this diagram. You should be able to remove the filler neck to allow you to work more easily.
https://www.lrworkshop.com/diagrams/land-r...ller_45023 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
8th Oct 2023 3:51pm |
All sorted thanks
8th Oct 2023 7:28pm |
How did you remove it. Always useful for other members to know if it happens to them.
8th Oct 2023 8:34pm |
notapnala Member Since: 12 Sep 2023 Location: Yorkshire Posts: 15 |
Yo, Shropshirelad.. how did you resolve this? I have the exact same issue, happened today. Any advice would be appreciated. Thanks
20th Nov 2023 12:54am |
