![]() | Home > Td5 > Oil Pan Drain Hole Stripped and More Saga |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
It messy but loosen the drain plug and let it spill out over your hand into a catch basin. Don’t let the plug all the way out just hold it and then screw it back in. 🤷♂️. (BTW which LR “specialist” here in Ontario did that??) Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Jhollow Member Since: 27 Apr 2022 Location: Ontario Posts: 83 ![]() ![]() |
So a final follow up. I found a plastic tube that would fit down the dipstick tube. I marked the tube to just below the fill mark on the dipstick, inserted the tube and sucked up the oil to create a gravity drip. The hole was pretty small so it took 21hrs to extract 1.4 litres of oil from the engine. It's been rainy so I had the time. I just set it up and left the garage. I could have used a vacuum pump but the hole was so small it would have still taken a few hours of sitting there pumping. It's now less than a mm above the full mark so I'll leave it. I could probably extract another 100ml. Tomorrow it will be dry so a good day for a drive. This is by far the longest it has ever taken me to complete an oil change, start to finish. 2006 90 originally registered in Italy
