Home > Td5 > Oil Pan Drain Hole Stripped and More Saga
Page 2 of 2 <12
Ianh
I’m not familiar with the TD5 engine, but on a lot of engines you can get a kit to suck oil out via the dipstick tube. In general this involves the insertion of a tube into the dipstick tube and a vacuum pump, the cheaper ones being like a big hand operated syringe.
I would never drain an engine that way, however to remove an amount of overfill oil it’s an option if that can be done with a TD5, noting you don’t want the suction tube getting stuck or breaking !
Post #1011292 15th Oct 2023 11:13am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Jhollow wrote:
So after installing a new drain plug in I attempted to remove the oil filter. I didn't know there was a special tool for this so tried all sorts of things, including a chain strap which just ended up punching a hole in the side of the filter. So I brought it to a Land Rover specialist and he had the special tool and was able to remove the old filter and install a new one. Note to self to get special tool.
My problem now is that he over filled the engine by about a litre or so of oil. Is there a way of extracting a litre of oil without having to take the plug out the bottom? I would just like to avoid the mess but if that is the only way so be it. I thought I would ask the collective before proceeding. Thanks again.
It messy but loosen the drain plug and let it spill out over your hand into a catch basin. Don’t let the plug all the way out just hold it and then screw it back in. 🤷‍♂️. (BTW which LR “specialist” here in Ontario did that??)
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1011309 15th Oct 2023 2:25pm
Jhollow
Canada
So a final follow up. I found a plastic tube that would fit down the dipstick tube. I marked the tube to just below the fill mark on the dipstick, inserted the tube and sucked up the oil to create a gravity drip. The hole was pretty small so it took 21hrs to extract 1.4 litres of oil from the engine. It's been rainy so I had the time. I just set it up and left the garage. I could have used a vacuum pump but the hole was so small it would have still taken a few hours of sitting there pumping. It's now less than a mm above the full mark so I'll leave it. I could probably extract another 100ml. Tomorrow it will be dry so a good day for a drive. This is by far the longest it has ever taken me to complete an oil change, start to finish. 2006 90 originally registered in Italy
Post #1011459 16th Oct 2023 5:01pm
Page 2 of 2 <12
