![]() | Home > Td5 > New nocking sound after diff oil change |
Kozzy Member Since: 17 Jul 2023 Location: Milton Keynes Posts: 10 ![]() ![]() ![]() |
Hi everyone,
I have a 2001 110 td5 with a salisbury rear diff. Went for a drive all was good, parked on the main road that is level, to change the oil in the diff. I have a pump like this one below. https://www.amazon.co.uk/Draper-01082-Purp...mp;sr=8-21 Undone the fill / level bung plastic oil was pouring out. ![]() Click image to enlarge Undone the drain plug( metal with magnet, no metal on it ) and waited until it was all empty. Showed the hose of the pump in the oil bottle and the other side in the fill hole. Filled it up until it was coming out. Got in to drive it and i have this knocking noise now. https://youtube.com/shorts/F-i4M8rtsyU?feature=share This is how it sounds while both wheels are in the air https://youtube.com/shorts/5C7wDfZMzLw?feature=share The oil is 80W90, and it took about 2L. Anyone can shed some idea on what to look at? Could have i dislodged something with the hose? Its a slightly plastic hose, not a full rubber one. Thanks Last edited by Kozzy on 25th Sep 2023 8:55am. Edited 2 times in total |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3506 ![]() ![]() ![]() |
As excossack. If you tighten to much you can even drop it inside. It only needs nipping up.
You may use a bit of ptfe tape if you think it may leak. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
hi,
could be it, the bloody thing just goes and goes. I will try this tonight |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5920 ![]() ![]() ![]() |
Does strike me as being odd, having no flange to stop bung being wound in too far 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
now reading online i think the drain plug is proper tight, as i found it somewhat tight and i have done it up tighter lol Got da 110 TD5 2001
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1200 ![]() ![]() ![]() |
It's pipe thread which is tapered so it jams in. You do not want to overtighten it. No point.
There are more sophisticated plug designs, but this works perfectly fine and is simple with no gaskets required |
Yes, now it is evident that I have tightened them to oblivion. Got da 110 TD5 2001
That oil looks like it has water contamination, very milky looking. Check your axle breather. It ends up under the offside rear wheel arch. It should have a looped over end to prevent water from being sucked into the axle, but the pipe can perish close to the chassis and sit there in the worst of the wheel arch spray and dirt. The fact the even when jacked up the oil was pouring out suggests either the vehicle was pointing downhill when filled last time or the oil has become contaminated since then... Hence the above. OK, your knocking noise sounds tinny with a constant frequent impact like sound. Like a playing card in the spokes of a bike wheel, but more rigid sounding. Something is rubbing against the crown wheel perhaps. Have you lost something off the pump into the axle? There are two ways to find out: the first is an endoscope through the bung hole and the second is to take the cover off the diff. Only sure ways to know. Benefit of the second is you can get eyes on the gears, check for chipped teeth, etc. but also the opportunity to flush and clean out the axle if it is contaminated. If it were me I would take the Salisbury plate off and take a look. |
thanks for that.
The landy was not lifted for oil change, and it was on level ground. A good 200 - 300ml has poured out while only the filler was removed. The contamination part makes sense as it was more than 2L in it, it was a lot of fluid. The hose from the pump was a fresh hose i cut nothing on the end to fall in. The knocking noise does speed up as i go faster. I will remove the cover and get a gasket and flush it. Thanks Got da 110 TD5 2001 ![]() |
Best plan IMHO. Check that breather hose whilst you are under there.
will do thanks Got da 110 TD5 2001
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1107 ![]() ![]() ![]() |
Another diff noise
?si=a96tbYvH6jKUa6va&t=245 (at 4:00) And its cause ![]() ?si=Ho9c-yzFuZZDaaLs&t=149 (at 2:30) In the end Mike replaced the Puma's axle with a Salisbury one ![]() |
Sent it to bloody deep lads .... tooooo fffff deeep.
![]() Click image to enlarge ![]() Click image to enlarge Whats next? Will it survive like this ? Got da 110 TD5 2001 ![]() |
As a minimum, drain the oil to remove as much metal shavings as possible,
Better still is to take off the diff pan, and clean manually. Try to get a magnetic drain plug, if you do not already have one, so it picks up whatever you have missed. Then fingers crossed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
